I am trying to create a keyboard shortcut for the Find --> Find Tag/Attribute menu item. I know I can go to the command line and type:
map F2 command-name
Unfortunately, I don't know what the command name is for this and I don't see it anywhere in the Help.
Anyone have any ideas or suggestions?
P.S. I am using ArborText v5.3
In Arbortext Editor 6.0 the command is "map F2 FindTagAttribute". I do not have Arbortext 5.3 so let me know if this doesn't work for you.
Thank you Phil!
The command "map F2 FindTagAttribute" definitely works in ArborText 5.3
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
