Isodraw 7.1 Macro query
ptc-1663523
Hi all,
I am new to this so please be patient.
Below is a macro I created. I have added statements to explain what is happening throughout and It works fine if I load a CGM into isodraw and then run the macro.
The problem comes when I call the macro from the batch process tool. That's where it crashes and burns. I have also tried running this from the command line but the same thing happens.
It is pretty clear to me that closing the document is causing the batch tool to go down. So if anyone knows some extra code I could use to just loop within my macro the number of times, equivalent to the number of CGM in my source directory I think it would do the trick.
Any ideas would be appreciated.
One other question: is there a line of code I can use to lock and unlock certain layers?
Cheers
Macro test
#Save original document number as string.
DEFINE doc AS string
doc = 'ICN-' + activeDoc.name
#SELECT THE WHOLE DRAWING
select all
MESSAGE "the file's full name is: " + doc
Group Selection
COPY
##########works up until here using batch programme###################
#Closes source document
CLOSE CONFIRM_NO
#hard coded to open official Project Pageframe
Open "C:\Batchin\951pageframe.iso"
activeDoc.name = doc
ACTIVATE LAYER "Standard layer"
#Delete existing blank ERM and ICN numbers
Select if Text contains 'ERM'
Delete selection
Select if Text contains 'AAAAAA'
Delete selection
PASTE Selection SAME_POSITION
Ungroup Selection
DEFINE path AS string
path = 'C:\Batchout\'
#MESSAGE "File will be saved as: " path + name + extension
Save path + doc
#CLOSE CONFIRM_NO
End Macro
#Format for running from command line and saving as base iso format
#IsoDraw71.exe -batch -s"C:\Batchin" -d"C:\Batchout" -f0 -m"test"
1 REPLY 1
Only partial answers here unfortunately.
In regards to a method to have the macro cycle through...seemed like I had a better way of doing this before, but here is a screwed up approach since I can't remember
Sudo code:
  1. Add a new text element on an empty page (doesn't matter where).
  2. Populate it with a unique piece of text (something easy to find later).
  3. Export text (you could use xcf if you prefer, but you'll need to add object info to the text so that it exports).
  4. Once the file is exported you can use your unique text (ref #2) to find the line you want to edit. Then use cmd or whatever to get a directory listing.
  5. Once your file has the updated directory listing for that text element you can open the text file.
  6. The variable will now contain your listing. There is a character limitation, but you should be able to get fair sized loads like this anyways.
  7. Parse the element with the string tools to loop through all the names running your submacro.
Sounds like overkill but at the moment that's what comes to mind.
In regards to layer locking, no one line code that I'm aware to lock all but one. You'll need to loop over the layers.
macro layerLoop
     Define i as Integer
     Define CurrentLayer as Layer
     Define LayerName as String
     i = ActiveDoc.LayerCount
    CurrentLayer = ActiveDoc.Layers[i]
    While (Exists(CurrentLayer) = True)
          LayerName = CurrentLayer.Name
          ActiveDoc.Layers[LayerName].Exportable = False
          ActiveDoc.Layers[LayerName].Printable = False
          CurrentLayer = CurrentLayer.PreviousSibling
    End While
end macro
This macro has not been tested but the intent is turn exportability and printing off for each layer. Mod for you purposes. In order to turn one layer on (or off), just add a check of the LayerName to skip what you design. If you'll use this a lot, set it up as a submacro, add a global variable for the layer you want to turn on/off. You can then set the variable and call the submacro whenever needed.
Learn more about PTC/USER
FlexPLM Blog Post
Windchill Blog Post
PTC/USER Global Summit
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
