Older XML Object Iteration/Revision with Graphics
kregimbald
Using Windchill 10.1 & Arbortext Editor 6.0
In order to view an older iteration/revison of an xml object we currently add the file to our workspace or to a baseline and then view the file in Arbortext Editor. We then save the file outside of Windchill in a folder.
The problem we have is this...when the xml file is saved to the folder and the user wants to view the file, sometimes the graphics appear within the xml and sometimes they do not.
My question is this....Are the graphics (tifs & gifs) supposed to be saved to the same folder outside of Windchill? If so, why are they not saved in the folder? Or, is there something else that causes the graphics not to appear within the xml?
By the way, some users do not have a problem seeing all the graphics within the xml whether accessing through their workspace or through a baseline.
Discovered that after the the "save as", the graphics are dropped from the xml if the xml file is moved into another folder. Seems the graphic file path is not recognized in the other folder.
The link (path) to the graphic needs to be altered in order for the graphic to be recognized in the new folder.
Learn more about PTC/USER
FlexPLM Blog Post
Windchill Blog Post
PTC/USER Global Summit
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
