Tips and Tricks for Optimal CAD Interoperability with Creo
Tmetcalf
Emeritus
Most companies live in a multi-CAD world. Whether you have a mix of internal CAD tools, or you are collaborating with vendors or suppliers using other CAD tools, you need an environment to minimize disruption, and provide accurate, high value CAD data when and where you need it.  The optimal solution is different depending on your needs. Sometimes a STEP file is sufficient.  If STEP is not enough, Creo’s Unite Technology and Flexible Modeling capabilities may meet your needs.  If your requirements dictate that you must have a native, parametric model in Creo, or that you provide native, parametric data and associative drawings to a customer or supplier in another CAD format, manual re-modeling is not your only option. This session discussed some useful tips and technology to help users operate efficiently in a multi-CAD environment
0 REPLIES 0
