FLO EFD problems
ptc-2206153
FLO EFD problems
Hey, so I have the flow analysis software setup as instructed in the video. I followed all the steps, except I had to use the license manager after the setup, and I have a client license from our coach. When I start up proE it begins and the floEFD.PRO splash comes up, sounds good right? I thought so too, but when I loaded an assembly the toolbar disappears and I cant do a flow analysis. What should I do?
Hi Mark, The issue is that you have an older builf of Pro/E WF 4.0 Schools Edition installed. You need to be using M092. This is avaiable for downlaod from your collaboration project. Here is the specific link - https://first.ptc.com/Windchill/netmarkets/jsp/software/list.jsp Click Pro/E CD1 and CD2 + EFD to download the required application. Give that a try and if you still have issues....send an email to -. Thanks, Mark
