Hi Kate, Thanks for the comments. I see the issue and we will update the Material library for ALUM-6061 to the proper value of 0.0979 lbm/in³. In the meantime, you can open the material dialog in Pro/E and edit the density value of ALUM-6061. This will then be changed on the system for future use. Sorry for the inconvenience. Regards, Mark
