Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi I have a schools edition of wildfire 4.0 and this is the first time Im trying to code for Pro/E. I am unable to locate Visual basic API if there is one. Does the schools edition come with it?
Hi Caroline, I am sorry the SChools Edition doe snot allow toolkit applcaitions to be created or run. This can be used with the edition on campus. Do you have access to it at school? Thanks, Mark
I have access to it at school but I am unable to locate the api. Maybe because I am a beginner or something but I simply am unable to figure where the API is supposed to be in the edition on campus. Caroline
