AVI file
AVI file
I was accessing one of the Study Works resource file (example systems of linear equations) and this file is .AVI file and when I hit play, it says failed to launch server application.
I have reinstalled studyworks twice already. Did I fail to install a program(s)?
Phebe
AVI file
Try running the regtool.exe found in the StudyWorks directory.
PKA
AVI file
You may need to install the free version of Real Player, which will install most of the common AVI codecs.
Unfortunately, there are literally dozens of "AVI" formats and your computer might not have gotten the codec that reads the AVI files in Studyworks.
TTFN,
Eden
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
