New Command in Toolbar
The new command button in the toolbar give me a blank worksheet while the new command from the pulldown menu gives me the template choices. How can I change the toolbar button to give me the templates choices?
David Kerins
The toolbar button New provides the normal template. This is a Windows setup, and not something you can change. If you want to change the normal.mct you could edit the file in your template directory. However, be sure to save the original normal.mct. One way to save it would be to rename it normal.mct.old.
Julie
