Simplifying Rational Expressions
MusicMonkey-dis
I do not understand if the following equation can be simplified.
x squared - 3z squared
2x squared - 7xz + 3z squared
If it can be simplified, how? In general, when a question like this comes up if there is an equation in the numerator that is not in brackets and two separate equations separated by brackets, can it be simplified. THANK YOU VERY MUCH. 🙂
8 REPLIES 8
>MUCH. 🙂
Look more closely at the denominator:
2x2 -7xz+3z2
=(2x-z)(x-3z)
TTFN
Could it be simplified to :
x + 3z
2x - z
or is the furthest it can be simplified
(2x - z) (x - 3z)
Thank you 🙂
Not unless there's a typo; you would have needed x2-9z2 to get (x-3z)(x+3z)
TTFN
could you reduce the numerator because of like terms by cancelling out the x - 3z in the denominator.
For example:
(2x-z) (x-3z)
could it become
x - 3z
(2x-z)
If no why not?
>the denominator.
>For example:
>(2x-z) (x-3z)
>could it become
>x - 3z
>(2x-z)
[x� - (3z)�]/[(2x-z) (x-3z)] = [ (x-3z) (x+3z)]/[(2x-z) (x-3z)] = (x+3z)/(2x-z)
You can cancel it as you expected, but note that you will have an x+3z on top.
Craig
I was wondering, in this question to simplifying rational expressions ??
Find (-6x^2 - 4xy + 8x)/(2x)
do they want me to find out what the variables are, or do they want me
to do something else with it? That is the exact way they have the
question written down.
This thread in over four years old, you might want to start a new thread.
Mike
Ok....Thnx mike...for the reply......
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
