Stoichiometry
Stoichiometry
hey, if anyone can help me on this problem, that would be GREAT:
When M2S3(s) is heated in air, it is converted to MO2(s). A 4.000-g sample of M2s3(s) shows a decrease in mass of 0.277 g when it is heated in air. What is the average atomic mass of M?
M is the missing element that has to be solved for.
S is Sulfur and it is 32.07 amu
THXXXXXXXXXX
Stoichiometry
>GREAT:
>atomic mass of M?
>amu
>THXXXXXXXXXX
First, come up with the process equation for the conversion, with the correct balance of the unknown sulfide to unknown oxide. What happens to the sulfur is irrelevant, all you need is how many sulfur atoms are replaced by oxygen atoms. The difference in atomic mass is divided into the change in mass of the sample to figure out how many moles of of unknown there are, which will allow you to figure out the atomic mass of the unknown.
TTFN,
Eden
Stoichiometry
thx for explainin, but WHAT???? can u please be more clear, like step by step on what to do. BUT THANKS FOR HELPING.. I REALLY APPRECIATE IT
Stoichiometry
> Figure out the balanc for the equation
M2S3 --> MO2
> The change in mass for the unknown is due to the difference of atomic weights of sulfur and oxygen as well as the difference in the number of atoms of sulfur and oxygen in their respective compounds.
> Calculate the number of moles of compound
> Calculate the atomic weight of the unknown atom
TTFN,
Eden
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
