another word problem
Please help with another word problem. Please explain in steps.
If a number is multiplied by 7 and this product is increased by 7, the result is 1 less than 9 times. What is the number?
Having the hardest time with word problems. I tried to check my work and it just doesn't come out.
thanks
>number?
Start by writing what you know from the problem.
n = the number
A number is multiplied by 7
7n
This product is increased by 7
7n + 7
the result
7n + 7 =
is one less than 9 times (the number)
9n - 1
7n + 7 = 9n - 1
Now try and isolate the n on one side and the numbers on the other.
Subtract 7n from each side
7n + 7 - 7n = 9n - 1 - 7n
7 = 2n - 1
Now add 1 to both sides
7 + 1 = 2n - 1 + 1
8 = 2n
Now divide both sides by 2
8/2 = 2n/2
4 = n
Now substitute the answer back in your original problem to check.
7n + 7 = 9n - 1
7(4) + 7 = 9(4) -1
28 + 7 = 36 - 1
35 = 35 Correct!
Mona
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
