different results?
different results?
hi all,
actual prob looks big but it should be a small error ( i hope 🙂
please dl the attachment.
thnx
different results?
I don't know where you got the values for the last two parameters to regel_srad down in the bottom set, but those are not the values actually used in the function. If you use the actual values of x8 and t8, you get the results as returned by the function.
Tom Gutman
different results?
t8 and x8 are in the wrong order in DEC
Stuart
different results?
thanx!
holy sh.. this happens too fast!
and there is no hint to see that...
but nevertheless my attachment had a basic error which i had recognized a few hours b4.
anyway, good help!!
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
