dll's in mcad 2000 old header
Highlighted
Newbie
I notice that the include file supplied with mcad 2000 professional does not contain any references for creating user defined dll's which perform file i/o. Where can I obtain the updated include file which contains the file i/o definitions.
TIA Marco
Highlighted
The trick with file I/O as far as I have found, is passing the filename to the function. To do this, you have to add the following definitions to your MCADINCL.H file:
// your function will be passed a const char * pointer
#define INFILE 13
// an OUTFILE is like an INFILE except it allows you
// to put your function on the left side of a := like
// the WRITEPRN() builtin
#define OUTFILE 14
These are new "type indexes" which you can put into your FUNCTIONINFO structure. Both INFILE and OUTFILE pass the filename as a char* and prepend the path to the beginning of the filename if necessary. OUTFILE allows you to use the function on the LHS of an equation like WRITEPRN.
Hope this helped,
Simon Chang
Highlighted
Yes in the end thats what I did, I took my old header and just used it. My point was Mathsoft should be providing it without users having to ask.
Marco
