Loading Tutorial Files
ptc-2356430
I have dowmloaded and, apparently, successfully loaded Cocreate PE as it starts and appears to be active. After downloading the tutorial files, 10 I think, I find I can only load one of them. Anyone have suggestions. I would like to evaluate this product but with this problem, and several inconsistencies in the getting stated tutorial, it has been frustrating if not a turn-off. Has anyone else ran into these issues.
Not applicable
(To:ptc-2356430)
Which kind of model files were included in the tutorials which you downloaded? Modeling PE cannot load *.pkg files; those are meant to be used with the commercial version, while PE uses the *.pk2 format. When you say you cannot ""load one of them"", what kind of files exactly do you try to load and how, and what happens when you try? Do you get error messages? Claus
ptc-2356430
(To:)
Claus, thank you for your reply. I think you have given me the answer. The files are not compatible with PE. Do you know if there is a tutorial avialble, with appropriate files, for the PE version? Thanks again - sgeorge01
Not applicable
(To:ptc-2356430)
Did you already try the tutorials at https://apps.cocreate.com/OneSpaceModelingPE/training.cfm? Claus
