pro/programming
ptc-1150591
pro/programming
I am trying to find a guide or tutorial that explains pro/programming for pro-engineer. Can someone point me in the right direction?
Nicole, In recent versions of Pro/E, since at least Pro/E 2001, I have not found any one place to find specific information on Pro/Program. You have to basically go into several of the training classes to find small bits and pieces of programming. I have, and have been using it for the past year, a copy of a book I have from a training class I took at a local vendor for Pro/Engineer Pro/Program version 2001. I copied the documentation into a pdf file, but it is to large to attache here. If you send me your email address (send to dennis.rehmer@otis.com ) I can send it that way to you. Dennis
http://www.amazon.com/Automating-Design-Pro-ENGINEER-PROGRAM/dp/1566901170/ref=sr_1_1?ie=UTF8&s=books&qid=1260885155&sr=8-1 I bought it myself, but haven't yet got around to reading it yet so I can't comment on how good it is.
1)Download the Pro/ENGINEER Help Topic Collections. Search PTC Support Reference Documents for: http://www.ptc.com/appserver/cs/doc/refdoc.jsp Product = Pro/ENGINEER Reported Release = Your release version Document Type = Help Topic Collections User Role = User Click the Browse button, this will download a zip file with the user guides. Look for a program.pdf file. 2)Pro/ENGINEEER Help Center http://www.ptc.com/cs/help/proengineer/wildfire40/html/usascii/proe/default.htm Functional Area = Fundamentals Modules and Books = -Program 3)Search the Knowledge Base http://www.ptc.com/support/index.htm search with Pro/PROGRAM This should return many suggested technique links such as "Using Pro/PROGRAM to Replace Components in an Assembly"
Just to add a follow up comment to the link that Carl George listed, as to where you can purchase a copy of the book he mentions. I myself purchased a copy, and wanted to let everyone know, that it is based around version 16/17 of Pro. I am sure the information is still valid, but the cd it has for examples are not in the most recent version of Pro/E. Dennis
Nicole,
I am not sure if you are still active in the planetptc community, but if you are I now need your help.
I had provided to you documentation on Pro/Program for Pro2001. I am looking to see if you have this still, and can send to me a copy. I left the company I was working for when AI sent this to you, and no longer have a copy for myself. I find myself now needing to do some Pro/Programming and would help if I could get a copy of this once again.
If you could email me a copy it would be greatly appreciated.
Dennis
