blend vertex, manifold from squar to round
Newbie
I know that I've done this during one of the courde I did
Now I'm unable to reproduce it
I need to create a general straight blend from a rectangular to a
circular section (devided into 4 pieces)
curves of the rectangle need to be "blended" to a single point on the
circular section, the quarter circles need to be blended to the
vertices of the rectangle
I've created blend vertices at each of the 4 vertices of both section
yet I still end up with a twist shape.
I've had errors stating that a blend vertex cannot be at the same
point as the startpoint
Can I do this using the solid general blend or do I need to
build things from surfaces
Can you help
Liek Lam
ASM Europe
RE: blend vertex, manifold from squar to round
All,
From the replies I received I conclude that I haven't been able to explain
where I'm going.
Attached a top-view picture of something I made with MS-paint.
As you can see two line from each of the 4 vertices on both the circle as
well on the rectangle
In my point of view this means blend vertex
(the triangles are actually flat faces)
Hope this explain better.
Liek
ASM Europe
Liek, try this link:
http://www.proecentral.com/portal/forum/msgDetail.asp?msg_id=2538&for_id=34
