mapkey to right click <rename> a feature or group
Highlighted
Participant
I am looking for a mapkey to rename features, groups or patterns in the model tree. just highlight the tree item and the mapket takes you right to the enter new name drop down box. kind of like F2 does inwindoz explore.
2 REPLIES 2
mapkey to right click a feature or group
You can rename items in the tree by a simple, slow double click. Click
once pause and click again to rename. That's easy enough to do, but the
mapkey will likely click too fast.
If you need a mapkey, you'll likely need to go through the menus:
Edit -> Setup -> Name -> Feature
Then click the feature/pattern or group to rename. You can assign that
to the F2 key by using the keystroke $F2.
Doug Schaefer
LinkedIn
Highlighted
Re: mapkey to right click a feature or group
For Creo 6, 7
Assuming
MapKey = F2
MapKey Name = YOUR_NAME
Add below text to your Config.pro
mapkey $F2 @MAPKEY_LABEL YOUR_NAME;\
mapkey(continued) ~ Command `ProCmdRename@PopupMenuTree`;
