Splice Issues
Highlighted
Splice Issues
I am a new user to RSD and I am having some issues creating splices in RSD 7.0. Sometimes I will create a wire or cable and try to splice it to another cable or wireand the splice will be created and other times it will not work. I am using the same artifact in both case. Also sometimes one of the wires in the cable will splice and the other will not. Iget an error,either "Fiber not found" or "Illegal port rotations".
Any suggestions on why this would happen and what I can do to fix it? Or any tutorials would also be appreciated.
Thanks.
1 REPLY 1
Highlighted
RE: Splice Issues
Additionally I could use any info on creating splices to shields and braid, and how to ground the backshell.
