Dear All,
I am running Pro/MECHANICA (Wildfire 2) on a standard 32 bit machine with
Windows XP Professional SP2, and need to run an analysis that is exceeding
the 2GB RAM limit. Without going into details, I cannot practically reduce
the model complexity and I need a greater level of accuracy than provided by
a simple quick check analysis. I would therefore like to install the 'fix'
detailed in PTC documents TPI 124474 and TPI 111330 which should allow
Pro/MECHANICA to access up to 3GB of RAM.
To this end, I have printed out TPI 124474 and TPI 111330, together with
information from the Microsoft website which is linked to these, and am
attempting to follow the instructions contained therein. While the
instructions provided within TPI 111330 regarding modification of the
boot.ini file seem clear enough, I have, however, been left a bit puzzled by
the following wording in TPI 124474:
2. Modify a local Pro/Mechanica installation with steps corresponding to
those described for Pro/ENGINEER in TPI 111330:
- copy IMAGECFG from a Pro/ENGINEER installation (or a Windows Resource Kit
CD) to the directory <mechanica directory=">\i486_nt\bin
- in the directory <mechanica directory=">\i486_nt\bin create a backup copy of
the engine 'msengine.exe' and run 'Imagecfg -l msengine.exe'
My specific concern is that TPI 111330 does not actually appear to contain
any information on the steps to follow for modifying a Pro/ENGINEER
installation - just how to modify the boot.ini file. Am I correct in
thinking therefore that all I need to do is modify the boot.ini file, copy
the IMAGECFG file from a standard Pro/ENGINEER installation (<pro engineer<br="/>directory>\i486_nt\org\IMAGECFG), save a back-up copy of the engine file and
then run Mechanica via the command line ".run 'Imagecfg -l msengine.exe'." -
or is there more to this??
If someone out there has already successfully installed this fix, I'd be
grateful for any advice that you can provide before I start messing with my
workstation.
Thanks in advance,
Simon White
