Auto Save during modelling
MickyD
Hi There ! Are there any means by which Wildfire 4 can be configured to 'Auto save ' whilst engaged in solid modelling operations. Whilst I am now getting used to saving the .prt file (and then deleting old versions) frequently during modelling - it can be infuriating when Pro-E folds, particularly during round creations.
Sorry there has never been a autosave function. Running the trail file from the last session is your only way to recreate the last Pro-E session. Usually the last line in the trail file will need to be deleted and then run it under the tools menu. One last thing save your round operations to the last or close to last features, if you can. They can be the most likely to crash Pro-E. I've had rounds kill Pro-E more times than I can remember. Certainly you can use certain selections in your geometry that will give more robust rounds.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
