"David Butz" wrote:
Moses, I gave this a little more thought, and foung a pretty easy way to do this. Copy all the files you want to convert to some new directory, and make that your Working Directory. Create a mapkey that does the following: File/Open/<enter>; File/Save a Copy/ACIS/OK/OK; File/Delete/All Versions. Now just keep hitting that key and it will march through the directory for you. Because you are deleting each file after converting it, the File/Open/<enter> command will just keep picking from the top of the ever shorter list of files in the directory. David
