I need to find a way to get a license to an employee who will not have access to the network because they will not be in the country. Does anyone have any suggestions? I can achieve 14 days, but need to get 30 days. Any help, comments, jokes...are welcome.
Thank-you,
Johanna Tournier
Auto Research Cente
4012 Championship Drive
Indianapolis, IN 46268
I got if from PTC knowledge base when I did this borrowing process for a customer in the same situation you are, but looks like you have already reach this limit of days however:
How to Extend the license borrow period beyond the default 6* days in Pro/ENGINEER Wildfire 2.0, 3.0, or 4.0.
The default "maximum" number of days to borrow a license is 6* days for all versions of Pro/ENGINEER later than Wildfire 2.0 (licenses are not borrowable in earlier versions).
The following environment variable increases the maximum for all versions of Pro/ENGINEER.
LM_BORROW_DURATION = N
where "N" can be set to any numeric value.
Wildfire 2.0 - 10* days Wildfire 3.0 - 15* days Wildfire 4.0 - 15* days
Thanks in advance
Guilherme Rocha - Tech Support Consultant
PLM Solutions do Brasil
“A goal without a plan is just a wish.”
Thanks in advance
Guilherme Rocha - Tech support
