When you have a missing model with dependency; there is supposed to be a Right Click > Break Dependency option in the reference viewer. How can I turn on this functionality? For some reason, when I select the link of the missing model and right click, the only option that shows up is the “info” option. Are there special configuration or permission settings that have to be set to allow users to manually break the model dependency?
I know there is an Auto Resolve option when checking in.
It does not always work and now I want to break these links before attempting a check in?
WF 4.0 M100 PDM-link 9.1
TracyWe submitted a similar issue to support and I believe WF4.0 M110 solved it.
Joe
