Breaking model dependency?
TracyWillis
When you have a missing model with dependency; there is supposed to be a Right Click > Break Dependency option in the reference viewer. How can I turn on this functionality? For some reason, when I select the link of the missing model and right click, the only option that shows up is the “info” option. Are there special configuration or permission settings that have to be set to allow users to manually break the model dependency?
I know there is an Auto Resolve option when checking in.
It does not always work and now I want to break these links before attempting a check in?
WF 4.0 M100 PDM-link 9.1
Tracy
Tracy,
I am not aware of any config options for this functionality.
For missing dependencies related to interchange assemblies, I have seen
both scenarios. Some could be deleted and others could not. No clue why
there is this difference. )o:
/Bjarne
Tracy Willis <->
08-12-2009 16:50
Please respond to
Tracy Willis <->
To
cc
Subject
[proecad] - Breaking model dependency?
?info? option. Are there special configuration or permission settings
Tracy-----End Original Message-----
Yes - That is what I want!
I select the radio button & select the link.
BUT the only option that shows is INFO.
Break Dependency isn't in my right click menu.
Does anyone know why and what I need to do to correct it.
Tracy Willis
Designer / Drafter
Cook Urological, Inc.
11OO West Morgan Street
Spencer, IN 47460
(812) 829-4891
(812) 829-1801 (fax)
Confidentiality Note: The information contained in this e-mail is
strictly confidential and privileged information which is intended for
the use of the above addressee(s) only. All other use is strictly
prohibited. If you are not the intended recipient, any review,
distribution or copying of this document is strictly prohibited. If you
have received this e-mail in error, please notify the sender immediately
and delete the document from all computer systems, or notify Cook
Urological at (812) 829-4891.
We submitted a similar issue to support and I believe WF4.0 M110 solved it.
Joe
