Changing the License Server for installed ProE users
ptc-2788835
Couldn't find any data on this anywhere, hoping its a simple thing! We recently changed our license server due to a divestiture, as a result we need to point the existing users to the new one. Besides reinstalling, is there an easy way to change the license server that Pro/E looks at for it's floating license?
Brandon There is the technique of going to your installion directory on the user machine, go to the bin folder, run the ptcsetup.bat command. This is similar to reloading the software from the CDs. You can change the license server from the correct window while the setup is running. If you have a lot of users then you could create a batch file, trail installation, that is sent out to the users and they will launch individually. If you only have a small handful of users then I would just go to each user and run the ptcsetup command. Eric
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
