Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Does the current version (either 20-0 or 2.0, as both were shown when I downloaded) run on Windows 7? It seems as though I successfully downloaded but when I try to go to the program, it wants a license. Where do I get this license?
Windows 7 sucessfully manages to block attempts by CoCreate Modeling Personal Edition to request and install a license key, so........the answer is no, it will not run. Check into similar threads already posted on this site for more information and a possible work around.
