Creating a New Library
ptc-171472
1-Newbie
We have determined that we need to break out PDMLink library up into two
separate Libraries.
I have created a template from our original library, and created two
libraries in our Development server.
I seem to have missed something though. I, as wcadmin, am the only one
who can "see" the libraries.
When I compare the original library to the two I have created, I see a
discrepancy on the Team page. The original library is noted as
Extended: Yes and the new ones as Extended: No
I am not sure how/where to change this.
I am specifying the same Shared team that the original library uses.
If I select the "Allow roles and/or members to be added locally in this
context" the creation fails with a "No such principal <null>" error so
the two new libraries were created without that being checked off.
Does anybody have a few pointers on Library creation they could toss my
way???
Thanks!!!
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator/Process Integration Specialist
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
1 REPLY 1
separate Libraries.
way???
Thanks!!!
Michelle McMasters
