Custom BOM Balloons
JonTribe
Custom BOM Balloons
Hi Chaps
I have a table / repeat region / BOM balloon related query... Could someone tell me, is it possible to have a custom BOM balloon that would return not only the index number but also other attribute values?? What we would like to do is to have data such as tag numbers and vendor part numbers labeled next to the balloon.... Any advice / ideas from all you experienced Pro-E expert types would be very much appreciated.
Thanks in advance
Jon Tribe
bfrandsen
6-Contributor
(To:JonTribe)
You can create a custom symbol that can call out any Pro/ENGINEER parameter as long as the parameter is listed in the BOM table.
I have attached our custom BOM "balloon" that calls out a single parameter that you could use for inspiration. You will have to dig in to how to create customized symbols with variable text to get it done.
Bjarne
