Goodmorning.
I have a question about the outputing of DXF from proe.
We output sheet metal flat patterns to a vendor to cut for us. Up untill this morning we thought it was working fine.
What we noticed is that the second sheet is not outputing to drawing scale. ie. sheet one and two don't output the same way.
Our config options are as follows.
dxf_out_format 12
dxf_out_drawing_scale yes
dxf_out_scale_views yes
Can anyone tell me why the second sheet does not have the same scale as the first when it is outputed.
Thanks for any help you can give me in advance.
Stephen
