Drawing Layer Control Setting
Newbie
I have a drawing that seems to set its layers independent of its models.
This appears to be something specific to this drawing. Is there a
drawing setting that would make this happen? I was pretty sure I had
the config.pro set so this wouldn't happen.
Bill Schmid
CAD Designer
Rexair
Cadillac, MI
www.rainbowsystem.com
Drawing Layer Control Setting [SUMMARY]
And the answer is:
Check the .dtl option "ignore_model_layer_status", under the
drawing options. If it's set to "yes", the drawing layers will be
independent of the model.
Now if I could just find a setting to force users to start a drawing
the right way so it uses the default .dtl file...
Thanks for the replies.
Bill
RE: Drawing Layer Control Setting [SUMMARY]
drawing_setup_file d:\pro_stds\configs\mycompany.dtl will make it look there or you can map a drive.
