Hello all, I have a template for an A4 sheet drawing. I also have my customized DTL file with some options. After I created my template, I changed some of the options on the DTL file. Now, whenever I create a new template based drawing, the new options are not applied. However, if I create a generic drawing, all options are applied. I have in my config.pro the location of the DTL file using option drawing_setup_file. Thanks in advance!
