Format parameter: ptc_wm_revisoin:d
Highlighted
Newbie
I use the ptc_wm_revision:d parameter in my format. If I create a drawing and choose Empty or Empty with Format, the Windchill version parameter will not display correctly. Only the parameter text displays. Even if i save and checkin the drawing and part the parameter will not display correctly. If i remove the format, save the drawing, then clear memory, I can then add the format and the parameter value correctly displays as it should. Does anyone know how i can add the format and have the WC version parameter display correctly without having to remove the format on every sheet, save and then re-add the format back in? This is a system parameter in the drawing. I am using WF3 M140.
Highlighted
Re: Format parameter: ptc_wm_revisoin:d
I'm having the same issue. I'm using the line: &PTC_WM_REVISION:D
IT works fine IF the dwg has been in Windchill already, and I'm replacing the file. It is glitchy if I create a new dwg and try and use the file. The old format we have with the "proi" (Intralink parameter) works fine, but Windchill seems really buggy. I'm going to start a new thread and log it as well.
