IDSX
ptc-2756516
IDSX
Apparently our license has one seat of IDSX, how do I access it? Should it show up in the applications menu? I don't seem to have any added functionality when I open wildfire 3. can you help?
During installation of Pro-E you have options as to which licenses to grab for launching. You can set your particular computer to other licenses by running the ptcsetup.bat in the bin directory of Pro-E. This is only the case if you have different licenses for your company. You can check to see if ISDX is loaded from the help menu in Pro-E under the tech support info. Once you have the license to ISDX then you can use the insert style feature (ISDX). You can also access some redefine options if ISDX is loaded. Good Luck Eric
