Importing 2d igs files to Wildfire
Newbie
I receive igs file drawings from our factories in china , usually they are of good quality and if not I can usually repair them. THis one file refuses to work for me. I bring it in and the scale is enormous. The drawing is D-size and when I bring it into wildfire it is at leat 40 times bigger than the format. Are there any settings or variables I can use to rememdy this. Any help at all is greatly appreciated.
RE: Importing 2d igs files to Wildfire
In the text of the IGES header there will be a model space scale. It usually appears before the units designation; it is possible you can edit this in Wordpad and see if it helps. Alternately, the config option intf_use_variable_size may help matters. Regards
Thanks for the advice Peter.
Hi, Mark Vasquez Can U tell me ur email ID. I Required Some Information Related to Rapid Prototyping.
