Dennis,
Maybe another practical solution is to put the license on your laptop and run a license service on it (this does not take up much resources at all). That way you can always run Pro/E on your laptop, and if you want to run it on your workstation you just have to make sure that the laptop is turned on, and connected to your local network, so the workstation can take the license from the laptop. I'm sure that this can always be arranged.
Regards, Patrick Asselman
---- Patrick Asselman <p.asselman@chello.nl> schreef:
> Hi Dennis,
> You can use license borrowing, where your laptop can take the license from your workstation for a fixed number of days. During that time you can not use that license on the workstation. You can not return the license before the borrowing time expires, so you have to think carefully about the duration of borrowing.
> Alternatively you can use PTC's online license management tools to transfer the license to your laptop. Essentially you then have two license.dat files for the same license, and both will work. Legally you are required to physically remove the license.dat on the PC that you are moving it from. You agree to doing so in the license management tool.
> Finally there is the option of using a VPN connection to your home workstation, and take the license via VPN. Of course this means you will always need to be online, be able to get through firewalls etc, and have a reliable connection.
> Best regards,
> Patrick Asselman
> ---- Dennis Varkevisser <dennis@flexibleengineeringsupport.nl> schreef:
> > Dear all,
> > I am working as a CAD consultant an I own one WF4 license. Once and a while I want to use the license on a laptop instead of my Workstation.
> > Is it possible to do this? Without having to install crack's or buy a second WF4 license? Is is possible to use a hardware-key (dongle?)
> > Kind regards,
> > Dennis Varkevisser
