PURGE Files from Directories
NEALROSENBLUM
Newbie
All,
Is there a command to purge all of the directories and subdirectories within a given directory (folder). Whenever I purge a given directory from withing Pro|E, I OPEN A SYSTEM WINDOW from the WINDOW pulldown menu. But this only purges the working directory. I am sure that I have many extra files in my JOBS folder that need to be purged, and I would like to clean up my hard drive.
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
<u>-</u>com
Spekan purge utility is a program that you install and you can then just
right click on a folder and purge from there. The utility allows you to
choose whether or not to make the purge recursive.
