Hello!
I'm occasionally doing FEM analyses in Pro/MECHANICA integrated mode. When the design study is finished I want to see the results, but every time I have to define result windows (Stress von Mises and Displacement) to show the results.
Is there an option or config file, which would by default show predefined result windows without having to define them every time? I know I can save results windows to .rwd file, but Mechanica also saves the legends and other properties with it, so when the results change, the legends aren't accurate anymore.
Basically, I would like to have a predefined result windows to show stresses von Mises and displacement with continous tone and shown as deformed.
TIA.
Jurij ÂkrabaP Pomisli na naravo, preden se odloči za tiskanje tega sporočila.Consider the environment before printing this mail.
Hello again!
I actually answered myself, since I went looking in the help files and found Results Template File topic.
Solution: Save results window as a template file and then retrieve it by Insert Results from Template menu option.
