ProE dropping out
Newbie
ProE dropping out
All
I have a user who is experiencing proe dropping out. He states that he
is working and it just goes away. XTOP.exe process is not running.
WF2 m260, install is local. Win XP
here is the std.out file
The 'selflt' toolbar no longer exists
(file \\iqhsaf3a.ww005.siemens.net\pleato00$\config.win.1).
The 'simulation_model' toolbar no longer exists
The 'tbDone' toolbar no longer exists
The 'feat_right' toolbar no longer exists
The 'tbProtCmd' toolbar no longer exists
The 'tbCutCmd' toolbar no longer exists
The 'tbSurfCmd' toolbar no longer exists
The 'tbChamferCmd' toolbar no longer exists
Exception - code was -1073741819.
any hints?
ProE dropping out
The first set of lines refers to the config.win file being from an
earlier version. Re-save the config.win to fix that.
The last line, the 'exception code', is why Pro|E is crashing. I don't
know what it means, but someone at PTC might be able to help.
Doug Schaefer
LinkedIn
