Producview ProE Worker Configuration...CadAdapter.ConvertCadFile failed Error, no LOCAL Worker avail
eankutse
I am running DVCS 7.0 M100, Pro/ENGINEER Wildfire 4.0, Pro/INTRALINK 3.4 M060 on Windows Server 2003 Service Pack 2 (Enterprise Edition) and I have a problem configuring a proe worker.
Details:
I am using the ProductView Thin Client and I get the following error when I select an Intralink (Pro/E) part in the ProductView GUI to try to get ProductView to translate and view the part. It looks like a Proeworker needs to be configured but I can ‘t get that configuration to work. This is the error message I get:
The ERROR MESSAGE AFTER I CLICK on link “Submit bearing_ball.prt to PROE for conversion”:
4/3/2009 9:40:56 AM: Status report begins at: 4/3/2009 9:40:56 AM
4/3/2009 9:40:56 AM: Name: 000-00233-0_1.prt Branch: main Rev: - Ver: 2
4/3/2009 9:40:57 AM: Checking EDR for 000-00233-0_1.prt main|-|2{}
4/3/2009 9:40:57 AM: Copying out all dependent files...(As Stored)
4/3/2009 9:40:58 AM: *** Copy out files: Starttime = 4/3/2009 9:40:58 AM Totaltime = 0 s
4/3/2009 9:40:58 AM: Checking Object Type...
4/3/2009 9:40:59 AM: Result: STANDARD 000-00233-0_1.prt
4/3/2009 9:40:59 AM: Submitting Part to ProE worker...
4/3/2009 9:41:00 AM: *** ProE conversion: Starttime = 4/3/2009 9:40:59 AM Totaltime = 1 s
4/3/2009 9:41:00 AM: Error: CadAdapter.ConvertCadFile failed Error: PROE conversion rejected, no LOCAL Worker available.
4/3/2009 9:41:00 AM: Status report ends at 4/3/2009 9:41:00 AM
I did run the proe2pv_config and provided the correct settings and so a proeworker.bat exists.
Also, I get a blank list of configured CAD Workers (in the "Current CAD Worker Configuration" list) when I click the “CAD” option in the Graphics Server Admin page (nothing is listed in the “Current CAD Worker Configuration”) . If I click “Configure” button in the "Current CAD Worker Configuration" dialog, it walks me through the process of specifying the Host, Data-Type, Where the EDS is running, the Execute command (I specify the full path of the proeworker.bat file in the setup directory that was created during the proe2pv_config). And when I’ve gone through all this and click “Finish” at the end, it brings me back to a blank list of configured CAD Workers (in the "Current CAD Worker Configuration" list), still without anything in there to select.
Emmanuel Ankutse
0 REPLIES 0
