Save a Copy Checkbox option
Newbie
Amit
While saving a copy of model in a workspace to any format other then *.prt , a check bok is given just above the OK button as marked in the image below.
do you have any idea about is its purpose. or Simply what happens when I check it while creating a copy of model in workspace (PDM link 8.0).
Regards
lalit sAini
It saves the other file type as a sub-file to the main file and is a real pain to separate later.
If your purpose in creating the secondary/exported file type is to send it out of your facility, uncheck the box before hitting OK.
Ben Loosli
Sr IS Technologist
Engineering Automation Systems
L-3 Communications/Integrated Systems
Waco, TX 76715
254-867-4069
