Saving in last dir opened from versus working
rcrisp
3-Newcomer
Proe users,
save_object_in_current no
Does this option set to no mean that files continue saving in the working
dir, even if a file is opened from another location? My set-up works fine
but another user is having issues with his parts saving to the server after
opening someone else's part from there.
Thank you
Ryan Crisp | Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
2 REPLIES 2
Ryan,
Here is some information on the MCAD forum from a similar topic:
. Working directory (MCAD forum):
dgschaefer
(To:rcrisp)
Ryan,
Here's what the WF4 help says about that option:
Saves the object retrieved from a directory where you do not
have write permission. See the override_store_back option. The objects
to be saved are set by the save_objects configuration option.
no-Does not save the object.
yes-Saves the object in the current directory.
Looks like it has to do with write permissions and works in conjunction
with a couple of other options.
That said, I believe that PTC changed the default behavior of the
file-open dialog a couple of releases ago to behave more like other
Windows programs. By default, Pro|E will now default to the last
directory browsed to rather than the working directory every time. The
config option 'file_open_default_folder' controls that behavior. Set it
to 'working_directory' for the old behavior (check the help files for
other settings).
Doug Schaefer
LinkedIn
