Spinning animation possible in CoCreate
CesarContreras
Is it possible to use a built in feature in CoCreate that allows you to somehow create an animation or a set of moving pictures to animate the model spinning? Not just manually rotating the model and saving a set of pictures, but if it can be done automatically that would be great. Thanks in advance.
6 REPLIES 6
No, that's not possible with the PE-Version.
In full version you can do it with the module "advanced assembly".
Did you try the "configurations" ? They can switch a part between two positions by using the smooth camera drive. Sometimes it looks good, sometimes not because the part chooses always the shortest way.
Another possibility is using this tool: http://osd.cad.de/lisp_3d_34.htm.
Unfortunately it is ony in german language. It makes a set of pictures by turning a part around an axle.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
Thank you very much highway 45! I was able to use the program you mentioned to make a series of images with the object rotating. Didn't have to modify any portion of the script.
Fine ! Pleased to hear that.
Hmm I wanted to do the same, but how do I use this script in CoCreatePE? The programming seems straightforward but how do I use it, is it a plugin, do I copy and paste it to some command line, or what do I do?
Hi Tristan !
Do you talk about this tool ? http://osd.cad.de/lisp_3d_34.htm
How to use it, you can see at http://osd.cad.de/anleitungen_01.htm
But that's a description in German, you are from Germany as I see in your profile ?
Thanks for the link. Yes I speak german it was very helpful.
But now I get a "Convert.exe funktioniert nicht mehr" (Convert.exe does not work anymore) after every spinning step. Or is it just Vista now?
