Ubuntu Linux for ProE 64bit
MarcHendrickson
Has anyone installed ProE WF4 on a Ubuntu Linux OS?
How does it work?
8 REPLIES 8
> How does it work?
Not Linux, but Solaris and Opensolaris (very similar to Linux) for WF4 &
WF5. If thats any help I'll elaborate.
Paul
Paul Gress
President
Rad Electronics Inc.
3122 Expressway Drive South
Islandia, NY 11749
(631) 243-7707
(631) 243-7708 Fax
www.rad-electronics.com
I would very much appreciate an elaboration! I am getting more and more nauseated by each progressive windows release and cannot fathom Mac OS. So taking a long hard look at Linux distributions to determine if there's a way to get my work done using it, or if I would have to run multiple operating systems.
In Reply to Paul Gress:
> How does it work?
Paul
Paul Gress
President
Islandia, NY 11749
(631) 243-7707
(631) 243-7708 Fax
Support for Pro/Engineer on Linux was discontinued quite some time ago.
Support for Mac OS-X has never existed. Solaris is not a Linux version.
Also, Solaris is a dead end, it is no longer supported for
Creo/Parametric (though this was done post WF4, so a WF4 version is
still available).
See for yourself:
Still hoping there will be an OS X verion one day...
> still available).
Actually WF5 (err Creo/Elements Pro) is supported on Solaris x86. WF4 was the last version for
Solaris sparc.
Creo 1.0 and newer only supports Windows Smiley Sad
> See for yourself:
I think PTC dropped support of Linux at WF3. I'm pretty sure they only supported the Red Hat distribution (but it probably work fine on others).
PTC has completely dropped support of all non-windoze operating systems now. Not sure when that happened but Creo 2 is all windoze all the time.
David R Gallup
Design Engineer
Standard Motor Products Inc.
5150 Pelham Rd
Greenville, SC 29615
Ph: (864) 297-1700 x243
Fax: (864) 297-8391
>> still available).
> Solaris sparc.
> Creo 1.0 and newer only supports Windows 😞
>> See for yourself:
Yes that's true. The last non-windows OS was for WF5 on Solaris. Although I did get WF5 running in a Virtual Box on Windows, Solaris host to create pdf's easier. I imagine it could be done with Creo 2.
Paul
> Regards
> David R Gallup
> Design Engineer
> 5150 Pelham Rd
> Fax: (864) 297-8391
> Please consider the environment before printing this email.
> The content of this e-mail (including any attached files) is confidential and may be privileged and protected by law. It is intended solely for the purpose of the person to whom it is addressed. If you are not the intended recipient of this message, please notify the sender immediately and delete the message (inclusive of any attached files). In addition, if you are not the intended recipient of this message, any disclosure, copying, distribution or taking any action in reliance of the contents of this email is strictly prohibited.
> Site Links: View post online <">http://portal.ptcuser.org/p/fo/st/post=115429&anc=p115429#p115429> View mailing list online <">http://portal.ptcuser.org/p/fo/si/topic=12> Send new post via email <">mailtoSmiley Tongue-> Unsubscribe from this mailing list <">mailtoSmiley Tongue-?Subject=Unsubscribe> Manage your subscription
