Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi, I'm on a locked license. I have just done a fresh install and I'm restructuring my file directories and do not wish to store my license in the same place. I know that there is a file that points to where the license file is stored but I cannot remember which file this is. Can anyone help me out please? thank you
Lee Just run your ptcsetup.bat in the installation directory of Pro-E. Click through that setup and point to the new license location. Running this setup is a quick way to reconfig Pro-E without going through the entire setup program. Eric
