Working on a Stl file
gbon
Hi all,
I have to work on scanned datas (human body part).
I've received an Stl file that I can import into a Pro Part.
I've tried to open it with a Rex license but "autosurface" tool is disable.
However, shape is complex and I don't have to transform it into parametric or analytic surfaces.
I would like to know how I could work on this and add or remove material (making some cuts, for example).
I assume that imported surface is closed and filled because it's weight is not zero but I can't cut it.
Any advice on how to handle this would be welcome,
GB
0 REPLIES 0
