CoCreate Modeling PE 3.0 has been released!
Its running on Windows 7, Vista and XP.
Cheers
Horst
I have been running CoCreate Onespace designer version 11 on my desktop running XP. But when I tried to install the version 11 software to my new desktop running Window 7, it doesn't let me install stating that it is 32 bit software and cannot be installed on 64 bit desktop.
First question, is there a patch or some way to install and run version 11 on Window 7?
I installed the XP mode on my desktop and install the version 11 but it runs really slow and the graphics refresh is REALLY slow and cannot use it..
I have allocated max RAM (3240 MB). I have 16 GB physical RAM on my desktop.
Thanks in advance for any help..
KR
the first version of Creo Elements/Direct Modeling - formerly known as OneSpace Designer - supporting Windows 7 is Creo Elements/Direct Modeling 17.0.
There have been some people trying to install Modeling 16.x on Windows 7 with success, but also under the agreement that this version is not supported on Windows 7.
The recommendation here is to upgrade to Creo Elements/Direct Version 17.0 or 18.0.
The graphics issue (delay) seems to be related to the fact that your graphicard is not used for this XP Mode and that Modeling is using software rendering. Recommendation is also to upgrade to the newest Version of Creo Elements/Direct Modeling to have fully access to the graphics and to the great new features implemented since Version 11.
