Randy: Place the config file in your "start-in" directory. To set the Start-in directory, simply right click on the icon you usually use to start Pro-E, then select properties, and the window that opens should have a "Start in" field for you to enter your desired location. You can either change this location, or move your config file to that location. I should note, that you can also change the location Pro-E starts in through PTC-Setup in your Bin folder. If you use the right click>Properties method, you will have to do this to any spot that Pro-E opens from (for example desktop icon AND the short cut found in the start menu), at least I did.
