config file
ptc-1423219
config file
Every time I open Pro E I have to reload my Pro_E-config file to recover my search paths. How do I set my config file as a default that automatically loads every time I restart?
Randy: Place the config file in your "start-in" directory. To set the Start-in directory, simply right click on the icon you usually use to start Pro-E, then select properties, and the window that opens should have a "Start in" field for you to enter your desired location. You can either change this location, or move your config file to that location. I should note, that you can also change the location Pro-E starts in through PTC-Setup in your Bin folder. If you use the right click>Properties method, you will have to do this to any spot that Pro-E opens from (for example desktop icon AND the short cut found in the start menu), at least I did.
config files are loaded as follows 1.Installation of pro-e directory under the text folder 2.Pro-E working directory 3.Finally under Windows your documents and settings folder If you want to make sure that it loads use #1. Make sure that you are not using a command that writes a new config.pro file to the text directory every time you launch Pro-E. This is one handy trick for keeping all users in a company on the same config settings. Eric
You need to either copy config.pro (and all other config files) to current ProE start directory (default at install is usually "My Documents" folder belonging to current user)or (preferred) dedicate a STARTUP folder where these files can reside. This folder is controlled by the ProE icon you use to start the program. Just right-click ProE icon> Properties> Start in ... This is a Text Box Dialog where you would type or paste the folder where config.pro resides. e.g., C:\WF4_Startup I have a dedicated folder for config.pro, config.win, tree.cfg, color.map, etc. The program will read all these config files at startup by default if directed to start in the folder where they reside.
Kevin
(To:WillyC)
Also make sure the file is named config.pro if you want it loaded automatically. This happened in another thread and caused grief because it was named something else eventhough it was in the correct directory.
