Hello all. I have a user that is using the same .dtl drawing file as everyone else. It's stored on the network and referenced in our config.sup. However, it appears that one of the options is not coming over for new drawings (just for him). Specifically, his arrowheads are unfilled when the file says they should be filled. Does anyone know what would cause this?
TIA,
John
Check the start drawing file that he uses.
The order of stl options that are read are
1st DTL file
2nd the template - start drawing
finally the individual setting for each drawing file, any changed setting that is saved in the specific drawing file is retained.
